1972 40hp Johnson-No power to Starter
boatingca
OK I found out what was casuing the problem but I have no idea what it is called.<br />It is located under the flyweel and has a switch which touchs a flat disc when the throttle is advanced and then kills power to the starter I guess to prevent the starter from activating in gear. It has a white wire which goes to a lead on the Starter sillenoid The problem is the spring inside is broken and I want to buy a new one.<br />Also how much and where can I get it and also a Choke coil?<br /><br />TIA<br /><br />boatingca
JB
Re: 1972 40hp Johnson-No power to Starter
Hi, Boatingca.<br /><br />Try www.tcoutboard.com<br /><br />Good luck. :)
