  #1
Old July 28th, 2003, 08:12 PM
Team Lowes 48 Team Lowes 48 is offline
Default High RPM's, Evinrude 60HP
I recently put a rebuilt powerhead on a 1991 Evinrude 60hp. The motor runs good but turns 6200 RPM's at WOT and when I trim it out she will run near 7000 RPM. I am 4 1/2 hours into the break in period and will not run WOT for more than a minute or so. I have the timing retarded 2 degrees and the book calls for 5-6K RPM at WOT. The motor is on a 91 Bass Tracker TX17 original and the prop is a 17 pitch. I don't know what the motor did before as I bought the boat with a blown motor. Any suggestions on what might be the cause and do I need to go up to an 18 pitch or higher prop? PS: Excessive RPM's were not the cause of the blown motor previous to rebuild.
  #2
Old July 28th, 2003, 08:18 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: High RPM's, Evinrude 60HP
Check the setting on the back of that tachometer. It should be set to number six (6). Any other setting will result in a false reading.
  #3
Old July 29th, 2003, 07:36 PM
Thanks Joe, All I have is a dial that reads 4 , 8 , 12 and 16. I also have a potentiometer dial that is for calibration on the back of the Tach. Is there a way to calibrate it?
  #4
Old July 29th, 2003, 09:19 PM
Joe Reeves's Avatar
Bill..... I have no idea as to what that tachometer is or if it's designed to work with that engine. The omc engines are designed so that the charging system operates the tachometer by putting out a six (6) pulse signal.Hopefully someone else will jump in here that has knowledge of the tachometer you have.
  #5
Old July 31st, 2003, 08:49 AM
seasprite2112 seasprite2112 is offline
bump
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Evinrude 60HP Dies on high rev Frogman Johnson & Evinrude Outboards 9 March 16th, 2007 06:27 PM
1991 8 HP Evinrude "Slips" at high RPM's VMIGUY Johnson & Evinrude Outboards 7 October 7th, 2005 05:26 AM
1971 60hp Evinrude Triumph low RPM'S under load sockey sally Johnson & Evinrude Outboards 3 August 20th, 2004 05:02 PM
RPM's going high.....90hr Evinrude Jmorrell588 Johnson & Evinrude Outboards 4 September 24th, 2003 07:17 AM
High RPM's jasonv Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 9th, 2003 09:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
