bobber head
- Nov 1, 2002
- 116
Greetings.<br /><br />Have a 17', '93 Nitro.<br />Evinrude 115 w/ turbo 13 1/4 X 17A prop.<br />Hole shot = one calander day.<br /><br />Opps, also have a power lift inbetween.<br /><br />Was advised to find the WOT rpm max and check it against what the motor should run at, then:<br /><br />Either- fix the motor, raise the lift, hammer the prop down to a 15 pitch, or switch to a 4 blade.<br /><br />Or get a bigger motor. (ouch)<br /><br />Makes since to me...anything I should know before Saturday's test run? Thanks, Bobber
