  #1
Old July 24th, 2003, 12:35 PM
spam0012 spam0012 is offline
Default 1984 to 1971 Evinrude 50HP power head swap
I have a 1984 50HP Evinrude that had thrown a rod bolt through the crank case. Now just recently a friend of mine who has a 1971 50HP evinrude and had torn up the lower end on some rocks. Now my question is can I take his powerhead and use it with my lower unit? Any help would be greatly appreciated.
  #2
Old July 24th, 2003, 02:16 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 1984 to 1971 Evinrude 50HP power head swap
OK, now youre REALLY taxing the ol memory bank! Lol!Weve done newer p/h to old mid section. The main thing (I believe) is the the older block has a curve or indent in one side of the base for the shift wires from the lower unit. Your 84 should have a straight mounting base area. So -- if we put the 71 on your 84 mid section there will be an open area that exhaust fumes will come up thru. You will have to weld a piece in there to match the mounting area of the adapter plate.OMC used the same base gasket for both because they added a piece of material to the gasket. It made a small "O" looking deal. Also look at the area that the shift linkage (on the 84) bolts to. Compare that to the block of the 71 which will not have any mechanical shift linkage. I THINK you can put your linkage on the older block. Maybe not.Interesting project! Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
power head swap? johngwp Johnson & Evinrude Outboards 3 July 22nd, 2006 09:07 AM
evinrude 35hp power head swap what66 Johnson & Evinrude Outboards 8 March 25th, 2005 07:28 AM
power head swap JTG Non-Repair Outboard Discussions 1 September 21st, 2003 08:36 PM
power head swap JTG Johnson & Evinrude Outboards 1 September 21st, 2003 08:36 PM
Evinrude 125hp 1971 power head strip down RPJS Johnson & Evinrude Outboards 1 August 6th, 2002 03:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
