Hello all. I have an 86 110 Evinrude model# E110TLCDC. The problem I am having is that it stalls out at WOT after it is held there for about 2 minutes it will also die at less than WOT but it takes a little longer. The motor always restarts but doesn't idle too great. Once I get it going again most of the time I can go wide open again, and repeat it all over again. I have fixed a couple problems. One problem was two pinhole leaks in the line coming in to the motor from the tank and going to fuel filter. Test drove again and still had same problem. I also found the line from the choke going to the carb was leaking I fixed that but never test drove because I am assuming this should have nothing to do with it. The hand primer stays hard for hours now so I am pretty sure all leaks are fixed. I also pulled all the plugs and they were in good shape nice and dry. Sorry about being long winded but I am trying to cover everything. Thanks in advance for any advice...
