I pulled the lower unit on my Johnson 9.5 and now it will not shift correctly. It will shift into neutral(middle) and forward(down), but not into reverse(up). I am sure that the problem is in the connection of the shift rod into the coupler at the lower unit, but I have removed and reinstalled it three times with no success. I have read about people measuring the shift rod to install... can someone explain this process to me?? Does this sound like the problem?? I need some major help on this one . Thanks for any advice.<br />Dustin
