  #1
Old July 20th, 2003, 05:51 AM
dcolpitts dcolpitts is offline
Default misfiring 1986 140 evinrude
long story try to make short, vro failed. temp sensors limited the engine to about 2200 rpm. stopped engine. replaced vro and engine starts.idles. misfiring just above idle as it tries to plan out,then starts to stall.pulled plugs shecked compression. 1 cyl not firing plug was like new conditon. checked coil with meter ok, did spark test on coil will arc about 1/2".carbs were rebuilt and fuel system replaced at same time as pump. enough background, does it sound like head gasket. compression was 95psi in that cyl compared to 110-115 in others. sorry for the detail, seems to help in long runthanks for help in past
  #2
Old July 20th, 2003, 06:34 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: misfiring 1986 140 evinrude
Okam.... It's possible that the head gasket is slightly flawed due to being hot. It sounds like you may have had a overheating warning rather than a VRO failure warning? How long did you run that engine after the warning horn sounded?VRO warning = Beep every other second.Overheat warning = Beep is steady and constant.Overheating could have caused gasket failure, and if just a slight failure, that would allow a slight amount of water enter the cylinder which would, of course, foul the spark plug.Bottom line.... Remove both cylinder heads and inspect the pistons, cylinder walls, sealing surfaces of the block and heads, gaskets etc. Install new gaskets if all looks well and torque the bolts to 18 to 20 foot pounds.Start with the left center bolt, then the center right bolt, then down to the next lower right bolt, then in an ever widening circle.Let us know what you find.
  #3
Old July 20th, 2003, 01:59 PM
thanks for reply joe. found out the alarm is not fuctioanalfor heat of oil. antoher project. did a 2nd compression test and was 108- 120psi on all syl. pulled heads, small amount of wear on the low compression cyl. the top cyl on the port bank was clean and the cyl below almost as clean. starbord bank both had carbon deposits. you were right on the overheating. I ran the motor about 2 minutes when it slowed down the first time. the vro failed with too much oil, piston broke not repairable. it may have overheated with too much oil? will order new head gaskets and keep postedp.s. removed plug in faulty cyl and engine started and idled as good if not better, had plug attacthed ground at same time good spark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
EVINRUDE 70hp still misfiring BMAN Johnson & Evinrude Outboards 8 January 22nd, 2009 09:41 PM
Evinrude misfiring after adjusting throttle linkage Walker Johnson & Evinrude Outboards 1 July 4th, 2006 11:41 AM
misfiring cylinder evinrude 50 sea cow Johnson & Evinrude Outboards 4 October 16th, 2004 08:19 PM
2000 Evinrude 90 Ficht misfiring DavioGradio Johnson & Evinrude Outboards 2 January 13th, 2003 05:23 AM
Evinrude 120 Misfiring framarjen Johnson & Evinrude Outboards 8 July 22nd, 2002 05:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
