I am looking for a manual release screw for a 1976 Calco tilt trim pump. This trim unit is from a 1976 115 Johnson. Also needed is the upper hydraulic cable since the brass screw that tightens it to the the cylinder is stripped. Or can someone recommend a replacement tilt/trim system.
