Talked to a "Johnson" man yesterday. His advice was to confirm the thermostat was working properly. He said if the head is not hot enough when trolling, that could contribute to the prblem if not cause it. Apparently Johnson has had some problems with the thermostat sticking open. This could be an issue sine the water temperature on my last outing was 36 degrees F. Will keep you posted when I have a chance to check it out.<br /><br />Smokey.
