skylarlake
- May 13, 2003
- 5
I have a 85HP Johnson 1980. In order for the boat (Nitro) to start I always have to turn the fuel primer valve on the motor itself to manual start from the run postion, turn the engine over with the key once and then turn the primer valve back to the run position and then it starts fine with the key. Is the primer switch going out? If so is it easy to replace myself and where would I buy the part online? Any direction would help, Thanks a lot!
