lostitnutter
- May 25, 2003
- 2
model BE60TLCUC<br /><br />engine goes great from cold, once warmed up runs fine until i reduce the throttle then it wont pick up again. primer goes soft (does'nt help if primer is pumped up again) pressing the choke sorts it out again until reducing the throttle then same problem happens.<br />i have disconected vro and am using premix, have rebuilt the fuel pump, and cleaned the carbs twice and replaced plugs.<br />compression test ok<br /><br />should primer stay hard at all times?<br />
