Re: JOHNSON COMMAND CENTER
If you have an allen head wrench set and a phillips head screwdriver....you are not so bad off.<br /><br />Remove the shift lever by removing the allen head screw in the center of the lever. The fast idle lever has a nut to remove. Then remove the phillips head screws in the bottom cover. Remove the screws in the top cover..should be apart.
