Re: Evinrude 115 crankshaft seal
It will leak down the lower unit from under the cowl. I thought it might be the carbs leaking, and by the time it got down to the lower unit, the fuel had evaporated. No luck, I've already rebuilt the carbs. It will leak the most, just sitting in the driveway. After a couple of days, It will be down to the prop. The upper crankshaft seal has already been changed. It doesn't seam to be leaking from the block seam. The only thing else I can think of is the lower crank shaft seal.
