Re: Johnson 150 GT?
Actually the crossflows were one of the most durable engines around -- providing they were set up right. Set it up to be capeable of 5900 to 6000 rpms with an average load and it will be fine. Lugging that motor in the realm of 5500 and it will coke up regularily. Do the decarbon thing to stay ahead and it might be OK. Set it up to turn less and it will coke up sooner and most likely die a horrible and premature death.<br /><br />They like good oil, are made to run on 87 octane and use Champion plugs. Keep water out of the oil, keep the combustion temps down, feed it a steady diet of good cooling water pressure and it will last a very long time.<br /><br />Good luck!
