I have an 1985 Evinrude VRO 90hp outboard motor.<br />I keep getting a beeping noise from the shifter (which is an OMC by the way)...it's not constant. It just keeps going beep...beep...beep. It beeps about once a second. If I shut the motor off and restart it, it won't beep for about a minute of 2 and then starts again.<br />This motor doesn't have an oil reservoir...I have to mix the oil with the gas. I don't think it is overheating...water is coming out in a good stream from the "pee hole" and the water is quite cold coming out of it. (Don't know if that makes any difference at all.)<br />I should mention that I removed this motor while I rebuilt my transom and just put it back on when it started doing this. I'm sure the wiring is just like it was befor I removed it. I had to splice some wires back together for one of the plugs but I got them right back like they were before.<br />Any suggestions???<br /><br />Thanks, <br />Dave CFI
