posted July 07, 2003 07:09 PM --------------------------------------------------------------------------------hi there...being new boat owner, i have already beagn to experience the trials and tribulations of owning a boat. in particular, i have v-6 200hp evinrude, carbeurated. it runs great above 1100 rpm's but at tends to stall a lot when at idle. also, if im driving, and bring it down back to idle, some times it stalls there as well. i belive its a 1997. thx, steve
i have the same problem it shifts fine if it doesnt stall just got it back from the shop for tune up please help us mine is a evin 9.9 (74) i should just take it back to shop still under waranty
sounds like throttle plates are still very slightly open when the timing retards fully. The plates MUST close fully, and the timing has to advance ever-so-slightly before the throttle moves, or it will be restart city, all day long.
thx for responding...it takes the throttle ok right up to speed. it holds rpm fine over say 1100. but below that, sometimes it slows down almost like its starving for gas or somethng. i have checked the bulb when it does this, and it seems a little soft. a friend of mine has a 2000 johnson, and his does the same thing. he replced the tank, fuel/water sperator, fuel lines, pump etc. and still the same problem.
I'm surprised the OMC experts haven't chimed in on this yet. Seems like the primary response to this type of problem is to rebuild the carbs. You should probably wait until one of the board experts gives you particulars on your motor. I have a 1989 Evinrude 150 with the exact same problem. I have just ordered 3 carb kits online to rebuild all of them. (Should be fun!)The fact that it runs well at higher rpms SHOULD rule out most of the ignition system.Keep us all updated!!
the motor only has 120 hours on it...its very clean...i cant imagine it needing a rebuyild, but maybe your right. i kind of have the feeling that the mixture is too rich. its oil injected. is there any way to adjust that? it seems to smoke a little too much. i feel like its too rich
Did the boat/motor sit unused for a while? Has it always had these symptoms since you've owned it?From what I've read, it doesn't matter if a motor has 30 hours on it, if it sits for a few months, there is a good chance the carbs will gum up... thus requiring a good cleaning (rebuilding)...
Do yourself a big favor and do not go fiddlin with adjustments without the shop manual. It will most likely get worse if you do. From your description you might check sync & link of the carbs & possibly a rebuild of the carbs. See:http://www.outboardrepairs.com/carburetors/
TRANQUILLO.... Regardless of what the problem might be, always check the compression, should be approx 100 psi and even on all cylinders. THen, with the s/plugs out, check the spark which should jump a 7/16" gap on all cylinders.If the above checks out okay, check the timer base under the flywheel. It should make a smooth transistion through its range up to the rubber bumper on the spark advance stop screw. Check it with the engine NOT RUNNING and in forward gear.If the timer base checks out okay along with the compression and spark, in all probability, the carburetors are fouled. If so, they will require removing, cleaning, and rebuilding.
dont forget about the recirculation fittings and vavles.this is from the manual- 90degree LV <120 to 300>a disfunctional recirculation system will cause one or more of the following:-erratic or poor idle-fouled plugs in lower cylinders-excessive smoke after extended idle when accelerating-idle sensitive to trim angle-you would not believe how bad mine was on the 120/140 i tore down.just a thought.
I have one more possibility which hasent been covered yet although everything i hae read is good advice.I wish to add. grab a torque wrench.I have had a similar problem.ran fine above 1/2 throttle or so.refused to idle.turned out that a crank case bolt had worked loose alowing it to suck air at a critical moment at lower RPM.noticed this by a fuel leak at the bolt head.never know but worth looking into.be sure you have your manuel for the torque specs.
