  #1
Old July 6th, 2003, 08:05 PM
longlake longlake is offline
Default evinrude- pee hole isn't shooting water in hight speed
I have a 50hp evinrude 50173s, the water comes out at a slow speed, when I go faster it gradually stops. Had it worked on last year, when there was no water coming out. Thought it just needed breaking in. any suggestions.
  #2
Old July 6th, 2003, 09:26 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: evinrude- pee hole isn't shooting water in hight speed
LongLake.... That model number indicates that the engine is a 1971 model, but that model does not have a water telltale outlet. You don't say exactly what you had done last year, but the explanation you give (if the engine is overheating), would indicate that the water pump is failing. If, last year, you simply had a impeller installed, have it redone and install a complete water pump kit.
  #3
Old July 7th, 2003, 05:34 AM
trumpetbucks trumpetbucks is offline
Longlake:You should see water coming out the exhaust port, but not a peehole. (I have a 72 Evinrude 100HP with same setup - no telltale.)Take Mr Reeves' advice, redo the water pump, then fish without worrying about it!Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Drain hole,Seep hole,water leaking from powerhead JDB123 Mercury & Mariner Outboards 5 January 29th, 2007 11:17 PM
Suzuki DT55 not shooting water out of the side hole teenfix Yamaha & Suzuki Outboards 15 June 23rd, 2005 07:12 PM
1996 Mercury 150-No water shooting from pee hole at idle boatman24 Mercury & Mariner Outboards 1 January 4th, 2004 12:36 PM
grease and water shooting out the prop Rob31 Johnson & Evinrude Outboards 5 March 18th, 2003 07:14 AM
Gas Shooting Out Spark Plug Hole chaboot Mercury & Mariner Outboards 8 June 9th, 2002 12:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
