Re: 2001 Johnson 115 runs rough at low RPM's
There are a couple of things you should look at. First, when sitting at the dock, how close to the water are the exhaust reliefs and overboard indicator? If they're with-in 2 to 3 inches, you could probably benefit by having the engine raised a couple of (mounting) holes. This would provide a little less back-pressure and possibly help to ease the roughness you're feeling. The other thing that needs to be confirmed is your wide open throttle (WOT) rpm. That engine should be up around 5500 rpm - on that 24' pontoon boat, if it's not running close to that it could be lugging (overloading) the engine. This will contribute to the roughness too. If the WOT rpm's aren't close to 5500 you'll need to change to a smaller pitch prop. This will help the engine's ability to accelerate that large boat as well as get it into it's powerband.<br /><br />The last item to look at is your idle rpm. It may be too high. The engine in forward gear should idle @ 650 +/- 50 rpm. If it's idling at 850 in gear, that's too high and could cause shifting troubles or damage the gearcase in the future. The idle speed needs to be verified with an accurate shop tachometer - the in the dash tach's on most boats can be very inaccurate and shouldn't be used for setting the idle speed.<br /><br />Two points to keep in mind:<br /><br />1. The Johnson motor do NOT drop cylinders for idling, all 4 run all the time (the Mercury 115/125 drops the 2 bottom cylinders below 1800 rpm).<br /><br />2. All carbureted motors have a transition point where the fuel circuits change from idle to off-idle and then to mid range. This covers up to around 2000 rpm, depending on the application (boat type) and how it's propped. This could very likely be what you're describing as roughness. Also, if it's still being broken in and is running on double oil mix, that will contribute to some rough running too.<br /><br />Let us know how things work out.<br /><br />-John
