  #1
Old July 2nd, 2003, 07:56 PM
charlie1939 charlie1939 is offline
Default Old Evinrude 2hp-cooling water, compression, over-heating, setting carb, year bu
I have a number of questions on an old Evinrude 2 OB.MODEL YEARIt's a Model 2502D, SN #E0003182 which I use on my O'Day Daysailor sailboat. I think it is from the early 70's. 1. Does anyone know the exact year? COOLINGThe motor has worked well for me for the couple of years I have owned it, but this year it overheated and quit after about 20 minutes at full throttle this week. This happened the first time I used it. I am using a 40:1 gas:oil mix (yes, I know 50:1 is recommended). I drained the fuel at the end of last season, kept the motor in my cellar all winter, filled it with fresh fuel mix and ran it in a bucket of water for a few minutes before taking it out for it's first run this summer.2. How much cooling water is it supposed to put out when it is running at full throttle? It spits out a spray, maybe about a cup or two a minute. Definitely not a stream... WATER PUMP IMPELLER3. What are the symptoms of a bad or worn out water pump impeller?ADJUSTING THE CARBAfter sailing home, we tried to start it and adjust the carb. It is difficult to start, but seems to catch after five or six sharp pulls of the starter rope with the choke on. Then it will not run at idle or at full speed, just in the mid range. It consistently dies as I try to increase or decrease the speed to the extremes, even when the high and low speed carb settings are changed. With or without the choke on, it will run at neither idle nor full speed, just in the mid-speed range. 4. Any thoughts on what this behavior means?COMPRESSION TESTI wonder if the compression is too low, I do plan to check it after I dig out my tester.5. Does anyone know what the normal compression pressure should be for it to run well? Is it measured the same way as for multicylinder OB motors (warm up the engine, turn it over 5-6 times with a screw-in compression tester? LOWER UNIT OIL DRAIN6. One last question; I can only find a filler plug is there a drain plug? Thanx for any and all info...Charlie1939
  #2
Old July 2nd, 2003, 08:35 PM
BF BF is offline
Default Re: Old Evinrude 2hp-cooling water, compression, over-heating, setting carb, yea
I can only help with a couple... I have a 79 (?) Johnson 2hp... #2 Mine spits water out the exhaust, not a continuous steam but a fair amount of spray. I'd think you'd be able to tell from touching the motor it was overheated. #6 There is only one plug in the L.U. it is the drain/fill plug. You fill from the same plug, with the motor on it's side. Fill slowly to avoid trapping air, and wiggle the prop a bit to try and work out any air that might be trapped in the L.U. As for your overall description of prob's, I'd imagine I'd start by going through & cleaning/putting a rebuild kit in the carb. Of course compression test would be a good idea... I don't know the spec's, and I'll admit I'm not a 2 stroke guru, but I'd be satisfied seeing anything 90+. You did try a fresh plug, right?? Sometimes the best place to start is with the easiest thing to fix. I've had bad plugs right out of the box.Anyway, hope this helps.Brent
  #3
Old July 3rd, 2003, 04:02 AM
cotterman cotterman is offline
your motor is a 1975
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Unequal cooling / heating LuckyPenny Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 March 1st, 2007 12:37 PM
Engine cooling water temp sensor 2000 yr carb 175 yamaha v-6 mclamown Yamaha & Suzuki Outboards 2 December 8th, 2006 08:12 PM
Rodbolt: cooling water temp sensor 2000 yr carb 175 yamaha v-6 mclamown Yamaha & Suzuki Outboards 5 December 8th, 2006 07:54 PM
Evinrude cooling water question. deerhound Non-Repair Outboard Discussions 7 November 18th, 2005 01:55 PM
90 hp evinrude-year and cooling leak tom thompson Johnson & Evinrude Outboards 2 September 22nd, 2003 07:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
