lostinthewoods
- May 5, 2003
- 15
Well I beleive that the moment of truth is at hand. The impeller is back on, the water lines now are all blown out and clear, the sparkplugs have been replaced, the pull cord is now able to retreat back into it's living quarters, the carb is cleaned (I think), gas tank cleaned out, fuel filter cleaned, I think that is everything. <br /><br />Oh yeah, the barrel is under the down spout and they're calling for thunderstorms tonight.<br /><br />Now is there anyone who can walk me thru the starting process. I would think it's very similar to starting a mower, but you don't know if you don't ask.<br /><br />(please correct me if I'm wrong)<br />1. mix gas 24:1<br />2. fill the tank<br />3. place motor lower unit in the water<br />4. open vent on gas tank lid<br />5. prime motor (how many pumps would you advise<br /> for a completely empty bowl?)<br />6. pull the cord<br />7. PRAY!!<br />8. CUSS!!<br />9. repeat #s 6,7,&8 as needed<br /><br />Once the motor is running I'll need to adjust the know on top to set fuel mixture (lean, rich)<br /><br />Have I forgotten anything?<br /><br />Thanks,<br />Lost
