Shawn Stinson
- May 7, 2003
- 2
I have a 1983 Ranger with a 150 Evinrude engine. I can never get it started at the ramp. It will often start for 1-2 seconds then die. After waiting for 15-20 minutes it will usually start after several attempts. There does not seem to be a difference when choking or not choking on the initial startup. Plus on random occasions this year, the boat will run a fine at idle or using fast idle, but when in gear it will bog down and not reach the power level necessary to get the boat up on plane. After a while of idling around, the problem will disappear..? I went fishing several times with the previous owner, and the problems never occured. I have owned the boat for under a year.
