  #1
Old June 28th, 2003, 11:57 AM
big dan big dan is offline
Default '83 Evinrude Fuel/Oil Mixture Problem
I'm currently running a 140HP V4, 1983 Evinrude outboard. My problem is that I'm fouling out the spark plugs. I need to know what my fuel/oil mixture should be. Right now I'm mixing 6 gal of gas with 16 oz of oil, or a 48/1 mixture. The plugs still continue to have a lot of oil residue on them. The spark plugs are NGK #5526-BUHXW-1. The original plugs being used at the time of purchase were Champion QL77JC4. I'm thinking that maybe if the oil mixture is right, then I may not be burning a hot enough plug in there. Thanks for the help.
  #2
Old June 28th, 2003, 12:43 PM
DJ DJ is offline
Default Re: '83 Evinrude Fuel/Oil Mixture Problem
big dan,Your ratio is correct (one pint-6 gallons 87 octane fuel) You don't need premium.The correct plug is a L77JC4. I believe those are the same as QL77JC4. I don't like anything in OMC's but Champions. Tried them all, the Champ's. work best.Your fouling could be from two reasons.1. Your carburetors are in need of attention and are running rich-float, needle valves.2. Your thermostats are stuck open, thus the engine never reaches proper operating temp.DO NOT go to a hotter plug. THat can be disastrous for your piston tops.
  #3
Old June 28th, 2003, 06:13 PM
Now that you mention it I have noticed that the temperature guage never quite changes while the outboard is in use. What is the optimal or normal temp my motor should be at while operating?
  #4
Old June 28th, 2003, 06:37 PM
OBJ's Avatar
OBJ OBJ is offline
Hi BigDan....Most of the OMC engines run a 140 degree tstat. At idle, the temp on the flat area right behind the head should run between 140 & 145 degrees. Flat out WOT, the temp will rise some. Don't know what yer temp gage says, but you want to get some idea of what temp it's reading at idle and compare that with WOT operation. Anything else would mean something is amiss.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
fuel mixture problem? Wizard1 Johnson & Evinrude Outboards 3 June 27th, 2006 10:34 PM
Evinrude Fuel Mixture warmitage Johnson & Evinrude Outboards 5 May 6th, 2006 08:08 AM
Evinrude fuel mixture cflucky Johnson & Evinrude Outboards 5 May 2nd, 2006 09:10 AM
Fuel mixture for 15 hp Evinrude Luvs2fish Johnson & Evinrude Outboards 9 July 27th, 2005 07:17 AM
fuel mixture for Evinrude 15 hp jmorgan457 Johnson & Evinrude Outboards 1 July 24th, 2004 10:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
