I emptied the lower unit oil since I am replacing the water pump as well. First thing clear water trickled out for a couple seconds and then slightly foamy oil came out and it all finally came out but didn't look very clean. At the fill hole up higher though the oil looked very clean. Is this normal and if there is a water leak what fixes that problem, replacing the water pump?? Thanks for your help.
