Proline Boat
- Jun 12, 2003
- 3
I have a 1990 v4 1.6L. I have change the the thermostats to see if that would fix it. The water pump seams goods I get 10 to 15 psi at 2000 rpms. I can run the motor for 5 min and the left side cinder heads run right up to 175F. Today I removed the left side heads to look for any kind of blockage. I did not find any thing. There is a light coating of salt all over the cinlderwalls. I dont think its thick enough to stop heat transfer. Is there any place to find a water pasage diagrm. I also ran the motor with the thermostats out of it and had the same problem. Its only the left side cylinder heads that over heat too.
