sparkroost
- Mar 23, 2003
- 312
HOw much of a change is there in compression once the rings seat?<br /><br />I have been building an evinrude 115hp 1973. I have the powerhead complete and am waiting on finishing up the transom mount stripping and painting. Got the motor on my workbench. It was starring at me... So I go to walk outside and bump my foot on the starter... one thing led to another.... 12v battery on the bench and I was in buisiness. 150 psi on all 4. Then I got to thinking that the rings are not seated and should get more..yee gads..<br /><br />Hopefully if all goes well it will be together this weekend.<br /><br />I replaced every bolt, most all grade 8 plated with the exception of the rods and socket cap screws in the case. Had the important areas re-surfaced. Decked the block. New pistons, bearings, lower carrier, raised intake and buble exhaust(even cut out the block at the bottom like the stock one). I AM SO EXCITED and ANXIOUS!<br /><br />I really tricked out the flywheel. Aerodescent paint with a swirl(gold, blue, green, purple, yellow swirl, like on a top. Polished Aluminum bracket on top, black motor, grey on the port covers, grey cylinder water passage covers. Looks bran new inside and out. Sorry to say though.. it looks like a merc with all that black. I did the leg and LU in black as well.<br /><br />Now all I need is a boat :-\
