The hot ticket is not a temp gauge but a water pressure gauge. Install a new waterpump and water press gauge. Note water press at all engine speeds, (idle, fast idle, low mid-range, etc.) and then watch the water press like you would a temp gauge. Any deviation in press from whats normal warns of a problem
before it overheats. Also monitors waterpump wear. My engine didn't have a tattle-tale either but it comes in the OMC water pressure gauge kit. Get the kit and we'll tell ya where to drill and tap the engine for the pressure tap fitting. Easy project.
c/6
Hooty
