Re: new motor?
Well, a friend of a friend put his finger over the plug hole and said there wasn't probably five lbs. of pressure on the two left cylinders. But, someone else said if that was true, it wouldn't start. I started it without the lower unit on.(for about 3 seconds).He added that one of the carbs proly wasn't giving enough gas and oil, and overheated the cylinders. After it cooled down, it would start.<br /> As for the lower unit, it looked like it tried to throw a rod or something, and is almnost protruding out of the casing. I tried to take the driveshaft out, and broke the molding on the unit.(around the water pump).I can turn the driveshaft in nuteral, but not in forward or reverse.The unit is not on the motor.I cannot get the unit apart. thank you.
