  #1
Old June 15th, 2003, 11:38 AM
dpowell2 dpowell2 is offline
Default Evinrude 8HP Cannot seperate lower drive from powerhead
My 8HP Evuinrude (1986 model, old friend) started to overheat so I shut it down and expected that the impeller needed a change. I took it ashore and started to remove the lower unit as I have done before. The unit would not come down after all bolts disconnected. Gear changing did nothing. I them tried to remove the powerhead, working from the other end. The same problem. I could not seperate the units. Any suggestions.I assume some bushing, shaft quide or something must have melted and is locking the shats but I cannot even begin to imagine where or how to seperate. HELP please?
  #2
Old June 15th, 2003, 06:33 PM
Sherman Sherman is offline
Default Re: Evinrude 8HP Cannot seperate lower drive from powerhead
I'm not sure of this story but, I think a friend of mine took the spur gear off the shaft in the gear box and just pulled hard enough to brake the water pump housing and got a lower unit off. But, he found the spline of the shaft seized to the crank and finally had to junk the motor.
  #3
Old June 15th, 2003, 06:42 PM
wayne h wayne h is offline
Master Chief Petty Officer
is this engine used in saltwater?? it sounds like the shaft is stuck in the bottom of the powerhead.u can set the engine upside down and get some pb blaster from your local auto store(this stuff is liquid gold)spray the shaft and let it run down to the powerhead let it sit for a few hours or days the longer the better. but keep spraying the shaft when you think about it. you want that stuff to soak in and work.i had to do this to a parts engine i have. it finally came free after 2 days of spraying and playing with it.
  #4
Old June 15th, 2003, 07:01 PM
Walker Walker is offline
This may seem like a dumb question but did you disconnect the shift linkage. I believ its behind the water intake screens on your motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
L-Drive Powerhead TVGuy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 9th, 2007 09:50 PM
90hp Evinrude powerhead on sea drive Tiderunner18 Johnson & Evinrude Outboards 9 March 18th, 2007 11:43 PM
suzuki df40, lower end won't seperate hidden bolt? the frenchman Yamaha & Suzuki Outboards 2 January 7th, 2004 05:06 PM
trying to seperate upper and lower omc stern drive danthern Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 6th, 2003 06:51 AM
Want to install new water pump but lower unit will not seperate! Old and Rusty Force & Chrysler Outboards 18 June 28th, 2003 05:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
