I had the head replaced on the starboard side due to a poorly installed helicoil that was done prior to me purchasing this motor. I noticed that the starboard side ran much cooler than the port side.Getting ready to put the boat in the water I felt I should change the thermostats. I found the cause for the cooling on the StB. side. There was no rubber in the stainless steel seal holder at the bottom of the T-stat. What is the recommended procedure to remove this st st cup. Can I replace it with a more conventional seal? I couldn't find the rubber part anywhere in the head.
