Hi Sparky
The seal in question is your lower crankcase seal. The spring holds it in place. The rubber o-ring seals water and exhaust crud out of the driveshaft splines. You only need to greese the splines on the driveshaft. Do not get any greese on the end of the driveshaft, this could have a hydrolic affect and load the crankshaft. The seals need no lube.
