I recently bought another lower unit for my 1960 Evinrude Lark 40. The seller stated that it was pressure tested. He forgot to mention that the pressure was zero.<br /><br />The pressure is leaking from the mechanical shift rod's passage from the gearcase. This is something I have trouble understanding. There is no obvious seal, or anything that looks removable in that passage. The parts catalogs (assume this is a typical 1960's lower unit) show a bushing and a seal and a gasket. However, these must have been pressed into that passage at the factory, as they are not visible. <br /><br />I think this design is typical for many years and models of OMC outboards. How do you seal a leak in the shift rod passage?
