I'm scared to death I've garbaged a power head.<br /><br />Put a new water pump in for the first time yesterday and put the l/u back on this morning. Followed the OMC manual to the letter. <br /><br />When I took the prop off, there was no keeper, just a cotter pin in the prop nut, and the prop nut was very loose, it took all of about 2 in-lbs to loosen. This worried me! When I reinstalled, I tightened to about 20-25 ft-lbs and prop still spun freely.<br /><br />Took a few tries to get the splines on the driveshaft to seat in the crank, but it eventually went in far enough for me to seat two of the l/u retaining bolts, stb side forward and prt side aft, then the aft bolt under the trim tab. Tightened 'em up in rotation. Never felt any resistance or anything that seemed odd or like anything was being forced. Connected shift linkage up on the first try--use a long pair of hemostats, they worked great. Tested shifting, shifted into fwd and hand-turned prop (wires off plugs) verified fly wheel turned clockwise. Shifted back to neutral, prop spun freely. Connected plug wires and tried to start. Nearly fired first attempt. Fired hard on second attempt and sprayed gunk all over garage door. Started on third attempt and TOOK OFF! cut it ASAP, saw RPM needle stuck on 5000. Examined linkages for a screwdriver or something I may have left in there, everything looked fine. Started again, and it TOOK OFF! Killed it again, maybe in time, I don't know.<br /><br />Could turning the prop (fwd) to verify the clockwise spin of fly wheel done something?<br /><br /><sigh>
