  #1
Old June 10th, 2003, 05:20 AM
stockyjr stockyjr is offline
Default How to adjust gear selector cable Evinrude 140 HP
I have fitted new gear selector cable, checked my Clymer manual guess what no info!!What I did was adjusted it to the mid position between forward and reverse but it clunks into reverse. Is there a different method or is what I have done correct?ThanksJohn
  #2
Old June 10th, 2003, 11:19 AM
DJ DJ is offline
Default Re: How to adjust gear selector cable Evinrude 140 HP
John,Just make sure that the shift shaft has a full throw in both forward and reverse.
  #3
Old June 10th, 2003, 12:58 PM
93bronco 93bronco is offline
Ensign
you didnt specify what year of motor, but this should basically apply.1-if connected at motor disconnect.2-move control to full forward position.3-rotate prop & move lever on motor by hand into forward gear <back towards head> (depending on motor)4-place shift cable on shift lever pin, washer, nut finger tite.5-pull on cable casing to remove play & adjust trunnion nut <wheel> to slide into cable lock.6-install lock cover & torque screw 60-80 inlbs <7-9nm> (depending on motor).7-shift control to neutral8-remove cable from lever pin on motor & make sure lower unit is in neutral.9-reattach cable to lever pin with washer, locknut & tighten. just has to be tite.-there is more about shift rod height adjustment if that doesnt work. helps to get an omc manual-if i missed anything some one will add or correct me. this is just basic info.just trying to help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
selector cable broke slanger33 Johnson & Evinrude Outboards 5 April 10th, 2006 07:30 AM
Gear selector cable connector connector blackwaterstout Johnson & Evinrude Outboards 0 September 9th, 2005 05:43 AM
how to adjust cable REEL TIME Mercury & Mariner Outboards 0 May 22nd, 2004 09:23 PM
Mariner 15 gear selector help Fishbreath47 Mercury & Mariner Outboards 0 October 26th, 2003 07:08 AM
Mariner 15 gear selector Fishbreath47 Mercury & Mariner Outboards 2 October 11th, 2003 07:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
