I have a 75 evinrude 115hp, It ran great when I drove it out of the canal, I rebuilt the carbs,fuel pump, changed impeller and lower unit seals. When I reasembled it, it wouldnt start. If I keep cranking the engine I will get a pop and a lot of smoke shoots out the exhaust. Someone told me the timing might be 180 degrees off. If thats the case how do you adjust the timing w/out the engine running?
