Re: 1973 Evinrude 85hp Help
So, do you know anybody who plays high-school basketball against that LeBrun kid? Must be pretty awesome.<br /><br />What's the history on this problem with the motor - did it start suddenly, or is there more to it? <br /><br />How sure are you it has no spark? Pretty easy to tell if you've got an old spark plug lying around. Bend the electrode back some, so you've got an 1/8 inch or so gap (makes it easier to see). Ground the body solid against something, maybe with a pair of visegrips or a clamp. Then try it while someone cranks the engine. You can do it one at a time on all 4 cylinders. Ideally, should be a FAT blue spark, not thready. If you know how to 'hot wire' the starter, do the test with the remote control disconnected - that'll rule out the remote as a problem. Your motor will start & run without the remote, so be ready to choke it or otherwise kill it if it starts. <br /><br />If no spark, then see what that manual you have describes for tests. I know you can check the resistance in the 2 timer base coils & the 4 ignition coils. Unlikely the problem's there, however, generally you just lose a pair of cylinders with a flaky timer base. It's been a while since I tested one of those PP4 powerpacks, but I vaguely remember you test a bunch of other stuff, ruling them out as a problem, and if they all test good you are left with the powerpack. Did you buy a used one?
