  #1
Old June 7th, 2003, 01:57 PM
Bearcamp Bearcamp is offline
Default Evinrude 15 with oil and water out the exhaust.
I just replaced the water pump impeller and seals in pump and the lower end. This is a model E15RENM and it works great. Idles good and has good acceleration. Good compression in each cylinder. After I replaced the pump and seals, I put it in a 55 gallon drum with water and ran it. I had water pumping like never before. Left it idle for about 5 minutes, then throttled it up (in gear) and water splashed up on the engine, but kept running. I probably ran it for 15 minutes. Took it back into the garage, put it on the stand. Came back 5 minutes later and I have white mess of oil and water dripping from behind the prop. Now on this model the exhaust exits from there. Dropped the lower unit and this gunk is up through the exhaust. But before I dropped it, I drained the gear oil and it was clean as can be. Is there a gasket for between where the lower unit splits. There wasn't one there from new. Where is this crap coming from or is it normal? The problem lays in the exhaust somewhere but can't nail it. I didn't notice this before I replaced everything. I had ran it in a barrel before and after running it noticed a little oil dripping from the prop and that's why I ripped it down.
  #2
Old June 7th, 2003, 02:00 PM
DJ DJ is offline
Default Re: Evinrude 15 with oil and water out the exhaust.
Bearcamp,Crack open the lower unit drain screw and see what he fluid looks like. If it's clean, your L/U is OK. If it's milky, you have water getting in there.It is a possibility that by running the engine fast, in the barrel, you areated the water to the point that it looks that way.You will always get some fuel/oil/water residue dripping from the prop. hub.
  #3
Old June 7th, 2003, 02:06 PM
Drained the gear oil from the lower unit and it looked like when I put it in, nice and clean.
  #4
Old June 7th, 2003, 02:07 PM
DJ DJ is offline
Bearcamp,If the L/U oil is OK, then the only other source of oil is from the exhaust. I would say normal, especially running in a barrel.
  #5
Old June 7th, 2003, 02:13 PM
But why is that normal running in a barrel. I mean this stuff looks like a heavy milky crap and drips on the floor. I could take my finger and just wipe off a big glob. But ya know, When your running, the exhaust comes out through the exhaust. And if your setting still running? I don't know.............ust want to make sure I didn't do something wrong and it's OK.
  #6
Old June 7th, 2003, 07:03 PM
Hooty Hooty is offline
Like you said, there's no gasket between the mid-section and the gear case. Burnt oil and water oozes out that seam. It's normal.c/6Hooty
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
exhaust water hot sloughbass Mercury & Mariner Outboards 2 September 8th, 2006 02:58 AM
'92 40 HP Evinrude Water and Exhaust BassnBobTn Johnson & Evinrude Outboards 2 April 29th, 2006 04:30 PM
25 hp evinrude water out of exhaust FishinTopsail Johnson & Evinrude Outboards 2 November 19th, 2004 07:51 AM
'87' Evinrude 35 H.P. Water & Exhaust leak under hood. lukefhardy Johnson & Evinrude Outboards 1 September 6th, 2003 06:33 AM
Water/Oil spraying out Exhaust Evinrude Jimbo 2962 Johnson & Evinrude Outboards 6 December 27th, 2000 10:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
