Wide Open II
- Jan 31, 2003
- 9
checking my engines the other day, and I became curious and would appreciate the knowledge of others. With a single engine on a v-hull, i can understand the ventilation plate should be even with the bottom of the boat or just slightly higher. However, with twins on a v-hull, you have two options. Should the outboard side of the engine's ventilation plate be even with the bottom or the Inboard side??? With my boat, it could amount to a 2" differential depending on which side of the engine you measure from.<br /><br />thanks<br /><br />Wide Open II
