  #1
Old June 5th, 2003, 12:34 PM
wizzo wizzo is offline
Default 300HP Evinrude rpms drop after warm
I have a 91 V8 evinrude. Its been to 5 outboard repair shops. It seems all the have is parts changers.All the electroics have been changed.The engine runs great out the water.When I run it in the lake it reaches 5500 rpms and runs for about 30sec then it drops down to 4000 rpms and it surges.I bypassed the vro pumps and install a electric fuel pump that pumps 5 lbs psi through 10ft of 3/8 hose.Still runs the same.Could it be one of the carbs?Or do I have enough fuel pressure?
  #2
Old June 5th, 2003, 02:56 PM
Bear Bear is offline
Default Re: 300HP Evinrude rpms drop after warm
I'm not sure but I'm thinking lack of fuel too.10 feet? Maybe the fuel hose collapses, or a bad primer bulb, the pick up filter in the gas tank or the anti-siphon valve.Is it possible to try another gas tank?
  #3
JB's Avatar
JB JB is offline
Hi, Mark.You seem to be dropping one or more cylinders when warm.Possible electronic/ignition problem? Start her up with the bonnet off and go through the whole ignition system, heating components one at a time with a hair dryer. If you can make the idle rpm drop you have found your heat failure. Next, inspect the inside of the bonnet for any signs of parts pressing against it when it is on. If you find any, inspect that part for possibly shorting out to the block when pressed by the bonnet.Possible fuel problem? Run her on the lake with the bonnet off. If the rpm drops (it may not because of the cooling air on the electronics) pump your primer bulb. No improvement? squirt some premix into each carb throat.If pumping the primer bulb makes her pick up you have a restriction in the fuel supply or a weak fuel pump.If premix into a particular carb throat makes her pick up, overhaul that carb with attention to the fuel inlet and float needle. It is probably running out of gas after a few seconds.Hope this helps. Let us know how you make out.Good luck.
__________________
RED SKY at night. . .
JB
  #4
Old June 8th, 2003, 11:53 AM
I took the wot needle out of all the carbs and found 1 stopped up.I took it out and ran it in the lake and it still does not reach max rpms.We had the baffle off the carbs and when you put your hand over the carbs to choke them the rpms go up.I tried a bigger pump still the same.Im going to take all the carbs off and go through them.I will let you all know how it turs out.Thanks for the responses. HAVING A BIG NICE BOAT THAT DOESNT RUN IS LIKE HAVING A BIG $@&^* THAT DOESNT GET HARD.
  #5
Old June 15th, 2003, 04:04 PM
I took my 25' Bertram out in the lake today after I replaced all the hoses to the carbs.The hoses to the carbs was 5/32.I change them to 3/16.I made up my own hose mainfold with all bigger hoses going to all 8 carbs.It ran 5600 rpms at 44 mph.Its running great !!! What a fathers day surprise.After 2 years off trying to get someone to fix my boat.Its fixed. Thanks for the helpHope this helps someone else too.
  #6
Old June 15th, 2003, 04:12 PM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
rpms drop off JSTSTRD Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 25th, 2005 03:12 PM
rpms drop from 4200 to 3000 a24rick Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 23rd, 2005 07:03 PM
Drop off in RPMs leetbeef9999 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 September 2nd, 2004 03:47 PM
rpms drop to 2500 dipstop Johnson & Evinrude Outboards 7 August 27th, 2003 04:34 PM
rpms drop, ...then hold steady jdcook Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 March 24th, 2003 02:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
