  #1
Old June 4th, 2003, 11:33 AM
voigto85 voigto85 is offline
Default 68' evinrude 55 shifting problem
on my 68'evinrude 55 i have forward and reverse but no neutral whats wrong?
  #2
Old June 4th, 2003, 12:38 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 68' evinrude 55 shifting problem
Voigto.... Since you have reverse, the two wires leading to your lower unit are fine. Neutral is obtained by applying voltage to only one wire, the green wire. This would lead me to believe that the neutral position of your shift switch is faulty.The shift setup of that lower unit is as follows.(Hydro Electric Shift)The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear. You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Preminum Blend" lube, commonly called "Type C". (A thinner lube) In neutral, you need 12v to the "Green" wire. In reverse, you need 12v to both wires, the "Green" one and the "Blue" one. In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear) To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed. This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift). With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded. You may crank the engine with the key switch or by energizing the starter solenoid with a jumper wire.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Evinrude 225 shifting problem mako231 Johnson & Evinrude Outboards 15 July 16th, 2008 07:41 PM
shifting problem tashasdaddy Boat Topics and Questions (not engine topics) 1 July 3rd, 2006 04:57 PM
Shifting problem 2ocnorb Mercury & Mariner Outboards 11 October 3rd, 2003 09:49 AM
Shifting problem Dan the pirate Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 2nd, 2003 04:45 PM
68' evinrude 55 shifting problem voigto85 Johnson & Evinrude Outboards 0 June 4th, 2003 11:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
