i own a 1983 15 hp johnson with a tiller when you pick up the tiller i can see both gears "handle and motor gears " there are 6 small gears and 1 larger gears and i think they are off. my handle reads fast,start,shift,slow now my handle will not go farther back than start.There is a slot for each of the bigger gears to fit in but right now they are on top of each other just by looking at it if i was to take the handle off and spin it "clockwise" it will be perfect and will probaly end up on the "slow" as mentioned above but just want to make sure before i take it apart any help would be appreciated "can't go fishing" thanks
