Johnson Mile Master pressure tank
TenE307
I just ordered the diaphragm (pt# 302563)for the tank because my last one was cracked. The one they sent me has a hole in the center(where the crack was) where the primer is located. Is this the wrong part or is there one without a hole in it.<br /><br />Thanks,<br /><br />Just trying to get running.
alcan
Re: Johnson Mile Master pressure tank
Hi Ten<br /> Do you have a plastic primer button?
TenE307
Yes. plastic Primer button - diaphram - metal plate attached to spring.
alcan
Hi Ten<br />If you have the plastic primer button, you need diaphram part# 376987.
TenE307
thank you, do you know a good place to order. my motor place cant order unless $50 spent. can you get just a tank repair kit.
alcan
Hi Ten<br />CAN'T, I hate that word. What they mean is WON'T. I'm sorry I don't know where the most convenient place for you to get this part. How ever they are not rare. Just start calling around till you find someone who will drop one in the mail to you. Of course you'll have to have a credit card. It may be a good idea to replace all the gaskets while your at it.
rolmops
Right now there are some on ebay.Search under Johnson outboard.
TenE307
thanks for the help. found tank repair kit at laing's outbaords.
