Re: motor ID??
Hi triplied2 <br />That's a 1967 6 HP. It uses a 50:1 mix. 1 Pint TCW-3 oil to 6 Gal gas or about 2.5 ounces oil to 1 Gal gas. Squirt a little oil in the cylinder before you try to start it and turn it over by hand using the flywheel, to lubricate the cylinder walls. See if you have spark and try firing her up. If it runs, or if it doesn't, get back with us and we'll try to help you out.
