  #1
Old May 25th, 2003, 02:41 PM
dixthree dixthree is offline
Default 86 evinrude 175 V6 rpms racing upon startup
I recently bought this boat and have changed the waterpump(original) and t-stats. When I went to run it on muffs the engine races over 6000 rpms and I immediately shut it down. Anyone have an idea what may be causing this? Thanks in advance!
  #2
Old May 25th, 2003, 06:27 PM
Reel Appeal Reel Appeal is offline
Default Re: 86 evinrude 175 V6 rpms racing upon startup
Are the control cables are connected to the linkages properly?The linkage's and engine timing must be synchronized.Control cable length must be properly adjusted before operation.Other than that you may have a bad vacuum leak somewhere.Have you installed new controls or cables on the motor?Go over the motor under the hood and make sure everything looks normal,and all connected.
  #3
Old May 25th, 2003, 06:55 PM
OBJ's Avatar
OBJ OBJ is offline
Hi dixthree...Ditto RA's suggestions. If unsure at what to do, best advice is to get a service manual. OEM is the preferred manual. It will explain in detail how to set the control cables up and check the control linkages for proper adjustment.You should also remember that any outboard on "muffs" will have a tendancy to rev faster because there is no back pressure against the exhaust side of the engine that would be there when the engine is in the water.Did you try to start the engine with the cold start lever down?
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #4
Old May 25th, 2003, 08:18 PM
yrag yrag is offline
Check to make sure the carb butterflies are not stuck open.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 4hp Startup problems james9000 Johnson & Evinrude Outboards 4 July 26th, 2005 04:44 PM
WOT RPMs 77 Evinrude 85 hp jmcgill89 Johnson & Evinrude Outboards 10 September 17th, 2004 05:36 PM
1960 75 HP Evinrude O/B startup after 10 years... Gumli Johnson & Evinrude Outboards 7 April 25th, 2004 05:25 PM
Evinrude V4, Smokin Heavy on Startup? peters Johnson & Evinrude Outboards 8 August 2nd, 2002 08:58 PM
Evinrude 9.9 startup woes! henderso Johnson & Evinrude Outboards 2 July 9th, 2002 09:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
