I have a 84 Johnson 25 HP and water is getting in the lower unit after I replaced impellar. I will replace drive shaft seals and thought while tore down may as well replace shift rod "O" ring. I have OMC manual for motor but not very clear. Do I have to disassemble the lower unit to replace this or can I do it with lower unit removed as in replacing impellar?<br />Any info is greatly appreciated.
