Re: Evinrude 115 run in salt water
For the thermostats, if your V-4 is like mine with the Bubble exhaust, ( looks like a Bell housing on the back of the engine between the two banks of cylinders), the thermostats are located below the bubble housing, [ really fun to get too ]....<br />You first should check your operating temp.. If O.K., go fishing and don't worry about it.<br />But, if you must dig into it, the easy way is to pull the power head if you have the means. This way you can get to the damn thing and save yourself alott of aggrevation. <br />Other wise, you'll need a 1/4" swivel socket set with extension, ( 8' to 12" ) to get down in there without dropping the lower bonnet. I think the socket size is either 3/8" or 10 mm.<br />The other thing you will need is a helper with plenty of patience.<br /><br />The problem is re assymbly. With 2 thermostats and 2 pop-it valves and to large springs,-- aligning, holding all the parts in place, and getting a bolt started will try the will of even god him self. You need 4 hands in there but there is only room for 2 hands. ( Thus the reason the other man said with a Grin, ( It's fun !!! ))<br /><br />Thus the reason I will pay the extra $10.oo for a power head gasket and pull the power head than change the stats in place.<br /><br />It is usally a time saver to do so beleave it or not.<br /><br />Hope this helps,<br />Bradster....
