1987 50 hp johnson just a thank you to all who helped
fpctim
rick, sloopy, all you guys thank you so much, i got my lower unit for 125.00,and i must say after changeing the water pump and lower unit oil,as well as pressure testing it ,its a keeper, i also ,got two power heads one with a rod through it but lots of parts as well as one that ran, 60hp (so the guy says will see) said the lower unit was bad on this one ,well maybe i can find somone who has my trim pump and needs parts i have who knows?,but Gods been good,thanks guys
fpctim
Re: 1987 50 hp johnson just a thank you to all who helped
wow nobody replyed
kg4nfb
fpctim, I was going to write to see if you got it back together and how it worked. I see it's working good now. Hope that takes care of you.
