Re: 2 cycle oil leaking from the propeller area
amartin8<br />Is the oil clean or is it black oil?if it's clean then you have a leak futher up under the cowls somewhere, you need to look for it. If it's Black thens it's burnt and most of the time this comes from long slow idle times or cold running engines. It shows up after you park up for a while and starts running out the leg. If this is the case then give the engine a good run before you put it back on your trailer, I'm assuming you have one of course.<br /><br />Kiwi<br />Still home of the America's Cup
