  #1
Old May 17th, 2003, 10:29 AM
Hartzhoop Hartzhoop is offline
Default Idling Rough.........84 Evinrude 115HP
84 Evinrude 115HP is idling rough and dies after 15 seconds or so. While idling it also seems to be jumping around alot more....Whats the likely problem?
  #2
Old May 17th, 2003, 11:41 AM
ob ob is offline
Default Re: Idling Rough.........84 Evinrude 115HP
Not knowing the history of the engine and whether the timing has been messed with or not I would be inclined to guess that your carb idle porting is fouled.Have you inspected or replaced the sparkplugs?
  #3
JB's Avatar
JB JB is offline
Howdy Hartzhoop.Go to www.outboardrepairs.comLook up rough idle. Follow the advice.If that doesn't do it come back here and tell us what you did and what you found out.Good luck.
__________________
RED SKY at night. . .
JB
  #4
Old May 17th, 2003, 12:05 PM
Checked the plugs and found what looked like one wet fouled plug. Replaced all four with new plugs. The idle is a little smoother....Thanks Also, is there a fuel pump rebuild kit for this engine(84 Evinrude 115HP w/VRO)??Thanks for the feedback!
  #5
Old May 17th, 2003, 12:11 PM
ob ob is offline
Yes.P/N 05004559.If your engine will run at high speed the fuel pump is not culprit.The kit also has no rebuild parts for the oil half of VRO.
  #6
Old May 17th, 2003, 02:23 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Rough idle is also a symptom of cold engine...which will foul plugs. Check the t'stat.
  #7
Old May 18th, 2003, 02:36 AM
Paul Witt Paul Witt is offline
Had the same problem on my "98" 115. Do a compression check. Unfortunately, I found a broken ring in the top cylinder. I had to bore the cylinder out and install an oversized piston.
  #8
Old May 18th, 2003, 09:46 AM
OB in Corpus....or anyone else....the fuel pump on this engine is faulty. It is idling, but will not run past an idle (have to pump the primer bulb to run at higher speeds) you mentioned P/N 05004559.The kit also has no rebuild parts for the oil half of VRO. .....I've disconnected the VRO and mix manually........Where can I get this rebuild kit????
  #9
Old May 18th, 2003, 10:47 AM
ob ob is offline
You can either get it from your local dealer or one of the online stores.Here's one. web pageThere is also a conventional fuel pump that can be got for your engine.Don't have the P/N for it.
  #10
Old May 19th, 2003, 08:10 AM
Ob.....the P/N O5004559 is a complete pump and not a rebuild kit(says the Dealer). The VRO pump is about $250 and the fuel only pump is $150. Is there an actual rebuild kit or less expensive fuel only pump that will work for this 84 Evinrude 115HP??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
idling rough Gudim Johnson & Evinrude Outboards 4 June 30th, 2006 10:06 PM
1995 115 Ocean Pro idling rough fireman57 Johnson & Evinrude Outboards 1 June 30th, 2006 12:40 AM
Still idling rough Scuda11 Johnson & Evinrude Outboards 8 June 29th, 2004 06:56 PM
85 evinrude 115hp stopped idling crazy charlie Johnson & Evinrude Outboards 7 August 19th, 2003 11:59 AM
Mercury 75.....1984? Idling rough PLEASE HELP? varouth Mercury & Mariner Outboards 1 May 20th, 2003 09:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
