  #1
Old May 16th, 2003, 07:58 PM
yorab yorab is offline
Default outboard bracket evinrude 75 hp
1963 evinrude 75 hp v4. When lowering my motor, there are 4 positions that the motor can lock into. When I bought the motor, there was no bolt or rod to lock the motor down. I bolted up a piece of all-thread, but I'm not sure which hole to use. Is there a better alternative than all-thread? Each hole locks the motor at a different angle in relation to the keel. Also the struts to assist lifting and lowering of the motor are not assisting very well. Does anybody know if these are still available?
  #2
Old May 16th, 2003, 08:28 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: outboard bracket evinrude 75 hp
Yorab.... The correct angle of attack is for the engine cavitation plate to be slightly lower than the keel at the transom and parallel with the bottom of the boat.Have the boat on the trailer, then sight the boat and engine from the side at a slight distance. This will allow you to view the cavitation plate and the bottom of the boat at the same time. Insert the rod, lower the engine, view and adjust (move the rod) as neededIf the engine is too far in, the boat will nose dive under power. If too far back, the bow will want to climb forever.Those two cylinders are not assist devices. On those older engines, they are simply shock absorbers.
  #3
Old May 16th, 2003, 08:40 PM
Hooty Hooty is offline
They call it a Thrust Rod and this is what it looks like. Tilting the engine out raises the bow of the boat. Ideally, you want the engine tilted out as far as it will go without the prop ventilating (cavitating).c/6Hootyc/6Hooty
  #4
Old May 17th, 2003, 09:19 PM
Thanks for the info fellas.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
looking for an outboard bracket 3car Non-Repair Outboard Discussions 1 April 8th, 2006 09:11 AM
unkown outboard bracket transom bracket 30" LOOK PIC.... phatmanmike Boat Topics and Questions (not engine topics) 4 January 25th, 2006 03:04 AM
Outboard bracket help Drowned Rat Boat Topics and Questions (not engine topics) 5 January 2nd, 2005 02:20 AM
OMC Aux. Outboard Bracket Mark Lett Non-Repair Outboard Discussions 3 January 23rd, 2003 08:58 AM
omc outboard bracket. help if u can! nhcfirefighter Non-Repair Outboard Discussions 3 July 27th, 2002 11:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
