Re: evinrude motor trouble
If you have an oil reserve tank on you motor, and are tilting it at an angle to crank it, Your oil reserve may just be low. If you checked the motor tank and it appeared to be full, you may need to tilt your motor to the full down position and then check the oil level. If this still doesn't stop the warning signal you may have a faulty sensor. Also check the oil level in the main tank.
